How can I use labview to build a dynamic clamp
Dynamic clamp is an experimental method in cellular neurophysiology. It is used to simulate the expression of membrane conductances. The key requirement is to measure a parameter, use it to calculate a number and then feedback that number as an analog output. It all has to happen on the fly at rates of 1,000 to 20,000 samples per second
(3,026 Views)
This is a similar question to "how fast can I execute a PID loop" type
question. LabVIEW RT would provide better execution speed (say around 1,000
per second). To go faster, we have always had to resort to a C routine that
we would call from LabVIEW.
Stu
frogdoctor wrote in message
news:101-5065000000080000002F150000-982303670000@quiq.com...
(3,026 Views)
