How can I use retentive memory?
I need to make a report of good/bad parts in daily an mothly basis, I want to put this data on a indicator but a dont want that this value get lost went the operator turn of the machine at the end of the shift. Does anybody knows how can i use some retentive variable? or other solution?
(3,431 Views)
How about saving the value(s) in HD? Do it at each update, periodically, or before completing execution of the program.
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
(3,425 Views)
This is pretty comnonly done with saving the values to an ini file. A more professional version would be saving to a network database so everyone could have access to the information at any time and without needing to run your program.
(3,422 Views)
Thanks i`ll do that
(3,363 Views)
