How can I use the report generation toolkits and build a stand alone exe?
I have built a help document with the Report generation toolkits. I can't get the app builder to create an exe that works. I've tried attaching the word and excel templates but still no luck. any suggestions?
Message 1 of 10
(3,535 Views)
Section in this doc on using toolkit in executable.  http://www.ni.com/pdf/manuals/323805a.pdf
Message 2 of 10
(3,526 Views)
Did you add the dynamic Vis for word and excel when you build your appplication as mentionned in the report generation toolkit documentation ?
When building applications with Report Generation Toolkit VIs, you must
complete the following additional steps:
• From the
Source Files tab of the Build Application or Shared
Library (DLL)
dialog box, click the Add Dynamic VI button to
add the following two VIs to the application:
_Excel Dynamic VIs.vi in vi.lib\addons\
_office\_exclsub.llb
_Word Dynamic VIs.vi in vi.lib\addons\
_office\_wordsub.llb
• If the application you are building contains the MS Office Report
Express VI, you must add any Word or Excel templates that you use
to the built application. From the
Source Files tab, click the Add
Support File
button to add the template files to the application. By
default, the custom destination for the templates is the same as the path
that appears in the
Destination directory field on the Target tab with
a
data subdirectory appended. Do not change the custom destination
for the files you add.
For example, if you are using the basic Excel template with the
MS Office Report Express VI, add
MSOffice_RGT_Template.xlt
to the application. The basic template files are located in the
templates\Report
directory.
Message 3 of 10
(3,524 Views)
Yes.  It will not work without dynamic vi's.
Message 4 of 10
(3,519 Views)
Thanks everyone,
I followed all these steps,
And - I've discovered that I also need to add every vi that contains a report gen tool to the support files list, about 20 different sub vi's that I'm using.
The build executable wizard is not very helpful in this area. I had to start with new project in my top level vi to gain access to adding all of the files I needed.
This process makes me wish I  stuck with Active X controls.
Message 5 of 10
(3,515 Views)
jdam,
Went back and checked all my past projects that use Report Toolkit.  I've never had to include all the subvi's that use the toolkit as support files.  Are your subvi's set to be reentrant?  What version of LV?
Message 6 of 10
(3,474 Views)
Centerbolt,
I'm using 8.2.1 and it won't work w/o all of the subs. My program is a help document that opens word and displayes screen shots of VI fron panels. W/o all of the subs, one for each panel, the word document opens but displays nothing.
Thanks for the input.
Message 7 of 10
(3,471 Views)
jdam,
So all the subvi's in question ones that you are getting the front panel images of?
Message 8 of 10
(3,462 Views)
yes
Message 9 of 10
(3,459 Views)
Here's a guess at what is happening.
I'll assume you are using the Append Front Panel Image to Report.vi.  If you dig down into that vi you'll notice that it is opening a reference to the vi you want the image of.  I'm guessing that in order to get the image it needs a couple of things.  One it needs to find the vi either in memory or by a path.  Second, the vi needs to retain its front panel.  Seems like Application Builder rips out all the subvi front panels by default.
Including the subvi's as dynamic/support files would satisfy both criteria.
Message 10 of 10
(3,454 Views)
