How can I use the write palette.vi in an application when it is not supported by run time engine
I am making an application, that is used for distribution, to create a palette. In my VI I take the VIs in a file and create a palette with them using the write palette VI. When I run the VI it works perfectly, but when I build it into a .exe I get the attached error. Is there a way around this?
Message 1 of 26
(4,263 Views)
That makes sense that it doesn't work because you aren't running it inside of LabVIEW.  Therefore, there is no palette to write to.  What you could do is create a *.mnu file and just put it in a location so that LabVIEW will notice it next time it is started.
If LabVIEW is running, you may be able to invoke the paltte write or refresh via VI Server.
Message 2 of 26
(4,255 Views)
What is the point of creating a palette when you have no block diagram or any way to modify the code?
Message 3 of 26
(4,242 Views)
Ok, I will try editing my vi to create a dumby *.mnu file to be called for the write palette.vi.
Message 4 of 26
(4,235 Views)
Once the application creates the *.mnu file the palette can be accessed from the block diagram on any VI on that computer.
Message 5 of 26
(4,228 Views)
What is it that you are trying to accomplish? What is the point of the operation?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 26
(4,227 Views)
Mike...
Seems like somebody is trying to write a VIPM.
Message 7 of 26
(4,214 Views)
Since everyone using it would have the deployment system, just distribute the VI. An exe seems pointless. With an mnu, the palette will be automatically updated with a restart of LabVIEW anyway. An actual mnu with items should be used. Why a dummy palette with no items?
Message 8 of 26
(4,212 Views)
Tried calling the application after creating the *.mnu file and calling it still received the same error.
Message 9 of 26
(4,201 Views)
The files does create a *.mnu with items the write palette.vi has to take an empty cluster of items any way before it can bundle the items like in the create palette.vi example so was giving what zealot said a shot. That is true everyone would have the deployment system. Trying to make an application because I was told to, if there is not away I will settle with distributing the VI.
Message 10 of 26
(4,195 Views)
