How can I write a array to other subvi when the program running?
Hello
I am working on a project with labVIEW, In the programme I made, there is an Case structure. And there  are several subvI, each subvi
belongs to one case.My question is when I process the data I a certain subvI, how can I wrtie this file(an array)  to another subvi and
show the file name in a listbox?
Many thanks
(2,614 Views)
You could try using a global variable or  a shared variable.
Brian
(2,604 Views)
