How can I write to an OPC Server?
Hello!
I was busy a few days with LabVIEW 8 to finish a special task, but now I've got problems to solve the following problem:
I have an OPC connection between a frequency converter and LabVIEW 8. With the example vi's I get the data out of the OPC Server (revolutions per minute).
So I can read data out of the OPC Server, but how can I write? I want to write several voltage values to the OPC Server that the frequency converter gets the required revolutions per minute.
Have you got any ideas? Are there existing example vi's to write data to an OPC Server?
Best regards and Thanks in advance!
(3,578 Views)
Hi
Basically said - if you can read, you can write - just do it the other way ;).
I made some programmes which communicate with a Siemens OPC-Server using Datasockets. I used these VIs to read and also to write. You just have to know wher to write and how the data has to look like.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,570 Views)
Hello.
Thanks for your fast answer.
I had the same idea, but i can't implement the "read example" to a solution, where i can write to an OPC Server.
If you have any examples, how you write to an OPC-Server, it would be nice if you can published it.
Best regards und Thanks in advance!
(3,555 Views)
No problem - I'll post you some code as soon as possible.
Using LV8.0
(3,547 Views)
So here it is - a little bit modified, but you should get the idea out of it.
If you have questions, I'll try to answer them ;).
Thomas
Using LV8.0
(3,543 Views)
Hi There,
I am having the same problem, but I cannot open this VI becuase I have an older version.  If possible could you please re-post the file saved as a LabVIEW 7.1 or earlier.  I would really appreciate this.
Thanks in advance.
Mike
(3,453 Views)
No Problem
Here you are - I hope it runs, as I got some message that some vis from vi.lib could not be saved for LV7.1
Using LV8.0
(3,449 Views)
