How can I write to text file colorful texts
I save system events in a text file,for example when system give warning message i want to write it red
(4,070 Views)
A raw text file does not have any formatting.  Maybe you could write to a Word document and format it in there.
(4,064 Views)
ASCII does not support text color, or any other style settings.  You can make custom reporting like using HTML or Word to have formatting.
(4,063 Views)
As others have said, a standard text file has no formatting. If you want to avoid a formatted language however, you could always put a keyword at the start of each appropriate line (so warning: text detailing the warning or error: text detailing the error) then write a specific reader to give you the colours. The reader could be in LabVIEW or just an add on into something like notepad++ without too much fuss.
So a programmed reader would look at the first line up until the :, then depending on the text beforehand colour the line appropriatly.
(4,044 Views)
You could add "rich text" tags, name the file *.rtf, and open it in wordpad.
(4,031 Views)
You could also add HTML tags and open the file in a browser.
(4,027 Views)
As others have mentioned, if you want to view text in different colors with an viewer/editor tool outside of LabVIEW, you must provide the necessary formatting for that tool.
If it works for your application to view the file using LabVIEW you can do this:
1) Place a unique key in each line that identifies an error.
2) Display the text in a Listbox and color each line based on that unique key.
You can fairly easily provide a stand alone viewer if needed.
This technique can also be expanded to provide multiple colors.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,003 Views)
