How can LabView's file size vi with I64 still cannot read file size larger than 4.2GB
I am trying to read file sizes using the get file/directory info vi but got incorrect file sizes if the files are larger than 4.2-4.3 GB.  I am using LabView 8.2 and Windows XP. I wonder anyone has seen the same problem?
Bryan
(3,104 Views)
This seems to be a bug in 8.20 and lower. It works fine in 8.2.1. 🙂
406GLS7U
Fixed an issue where the File/Directory Info function returns an incorrect size for files larger than 4 GB.
(3,102 Views)
Thanks Altenbach, looks like we need to upgrade LV again.
(3,094 Views)
Since there is this bug preventing us to get correct file size on files larger than 4GB with LabVIEW 8.20, I wonder if anyone has built a vi to call the GetFileSizeEx function with windows user32.dll call? Thanks in advance if you could post.
(3,082 Views)
GetFileSizeEx is a function in Kernel32.dll instead of user32.dll. Sorry for the mistake.
(3,078 Views)
