How can Spicify the coeff in a DFD Kaiser Design.VI ??
Hi People!!!
I want to design a FIR Filter with the Matlab coefficients. How can I specify the coeff??
This my VI:FIF DFD - FXP.jpg
Thank you very much!!!
(2,796 Views)
Hi flote,
you can integrate your matlab coe file into an integration IP file.
Here is an description how to do this.
Integrate External IP in the LabVIEW FPGA Module using IP Integration Node
i do not know if you can also go on this page there are also some informations.
FlexRIO FIR Tutorial CoreGen.zip
I hope this helps
best regards
Alexander
(2,762 Views)
Hi flote
attached a project with an filter. The signal was filtered with 40 Mhz.
In the Zip there is also a ScreenShot with the settings. The filter was tested with some frequencys.
best regards
Alexander
(2,742 Views)
