How can a GUI interface be made to show indicators(image display,numeric indicator etc.) in a VI on 3 different screens?
Can you give some example about this? I'm having some trouble with exactly how to do it. What I want to create is something like the following.
Message 21 of 27
(1,621 Views)
Hi worker,
I recommend to use a MultiColumnListBox (MCLB) instead of a simple string indicator.
It will become much easier to select the colors for those error indicators…
Open the example finder in LabVIEW to look for examples!
Message 22 of 27
(1,600 Views)
@GerdW wrote:
Hi worker,
After much effort I did something like below but still there is a problem because I only want the second column to change color but it changes the color of a whole row.
Anyone know a better way?
Thanks for the replies  , but your answers are a bit cold  🤯 🙂
Message 23 of 27
(1,575 Views)
Accepted by topic author constructionworker
Hi worker,
I told you to use a MCLB.
You quoted my suggestion where i explicitely wrote "MCLB".
But in your VI you use a table!
And now you ask for "better ways" and "cold answers"…
Why don't you use a MCLB?
I don't understand your behaviour…
Like this:
Message 24 of 27
(1,555 Views)
@GerdW wrote:
Hi worker,
Like this:
Thank you for your answer. But is the difference between MCLB  and table so important here? Because I think they both do the same thing.
Solved my problem thanks for your help
Message 25 of 27
(1,543 Views)
Hi worker,
When you think they both do the same then complain about "cold answers" when they don't do the same!
Message 26 of 27
(1,501 Views)
@GerdW wrote:
Hi worker,
Hi GerdW,
I was just saying about this(changing font color) topic. But yes, there are differences for different topics, of course, it supports wider features.
Thanks for reply...
Message 27 of 27
(1,495 Views)
