How can a VI be both server and client?
Hi Rambaldi!
I am having same problem as you were having.
Can you post your vis which are working?
Message 11 of 15
(1,215 Views)
here is the code im using.
Message 12 of 15
(1,206 Views)
  • Why do you have two 100ms waits in the client? Since they execute in parallel, the total time is the same as if you had only one.
  • What is the purpose of the sequence structure around the server code? Makes no sense.
  • None of your "OR FALSE" code fragments make any sense. A plain wire would do the same thing.
  • both client and server know how big a flat boolean is, you don't need to send the size.
  • Can you explain what you are doing in the second true case of the server?
Message 13 of 15
(1,189 Views)
I have to talk to some legacy CVI (7.1) code that resides on the Unit Under Test and is running in the form of an exe.  That code is currently a TCP Client.  It was being called by some CVI tests that were bundled into a DLL, and each test was called from TestStand (3.1).  The tests within CVI are considered the slave, as there is a setup routine that calls RegisterTCPServer.
if ((status = RegisterTCPServer (ATS_TCP_PORT, ATS_TCP_Callback, NULL)) < 0)
To work within our existing architecture, however, I need to re-do (what is currently) the Server code in LabVIEW (8.5) and each of the tests will be called from TestStand (4.01).  In the CVI Server, the TCP_Handle was a static Unsigned, so the handle seemed to be valid for all the tests that wanted to use it from TestStand.
static unsigned     TCPhandle = 0;
In my mind, it would make most sense if the UUT code (what is now the client) were modified so as to be the server.  Then, each labview test (called from teststand) would open a TCP connection, send the message, close connection.  However, some would like to re-use the client-side C code if at all possible.  If I did that, the labview tests would somehow need to be a server, or I need to create ONE somehow that all the tests use, correct?  I thought I ran into this long ago, where the type for a TCP handle created down in a labVIEW VI didn't translate well into a TestStand type, so I couldn't keep the TCP Handle valid.
Any thoughts or clarification would be appreciated.
Message 14 of 15
(1,129 Views)
Message 15 of 15
(992 Views)
