08-17-2005 08:29 AM
Hello! I am still a starter with LabView (working with 6.1).
On the Front Panel of my VI the operator can use a ring control element to choose some (6) options. I am searching a way to block the scroll down menu of this ring element when a Boolean Signal is set. Only when this Boolean Signal is false, my operator should have the possibility to chance the ring or enum element.
Is this possible?
Hopefully
Lars
08-17-2005 08:46 AM
08-17-2005 09:27 AM
Yes I have and there is amongst others a point called “disabling ring control items”, but it only shows me a way to de/activate the ring item by mouse, but not by an internal signal. I also searched my library.
08-17-2005
09:51 AM
- last edited on
12-02-2025
02:38 PM
by
Content Cleaner
What Gerd meant was that you need to create a property node. Right click on the control or the terminal and select Create>>Property Node. Then, select the Disabled property, right click it and change to write and set the value you want (0, 1 or 2). You can change the boolean to a number by using Boolean to 0:1 from the Boolean palette. This property is common to all controls, not just rings.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
08-17-2005 10:34 AM
08-18-2005 06:16 AM
