How can do UnSubVI?
When I mark part of code and click on Edit-Create SubVI the celected code will change on SubVI.
How can I do oposite step. How can I do from SubVI normal code?
Message 1 of 15
(4,814 Views)
If you want to re-do the "create subVI" action whilst still working on it, try the undo function from LV.
If you have closed the VIs inbetween, there is not much you can do about it except copying the block diagram of the subVI back into the caller and then removing the subVI.
Norbert
Norbert
Expert: Geometry
Message 2 of 15
(4,807 Views)
You can edit your LabVIEW.ini file and change the option "inlineSubVIEnabled"
Or you can use the JKI Right Click Framework.
Jens
Kudos are welcome...
Message 3 of 15
(4,797 Views)
I tried this with undo but when I save and close LabView then is no way back. Any way how do in program doesnt exists?Smiley Surprised
Message 4 of 15
(4,795 Views)
One question yet.I cant find how change name of subVI...?
Message 5 of 15
(4,781 Views)
VIs are named once they are saved.
If you saved it with an improper name (e.g. 'Untitled 1.vi'), you can use the "Save As" function to rename it.
Norbert
Norbert
Expert: Geometry
Message 6 of 15
(4,765 Views)
Hi adssad,
simply mark the subVI in the project explorer and press F2...
Message 7 of 15
(4,755 Views)
Isnt working in explorer project. On click F2 doing nothing.
Message 8 of 15
(4,750 Views)
when I select a VI in the LabVIEW project explorer and press F2 I can rename that VI...
Message 9 of 15
(4,747 Views)
As far I know you cannot go back to the code from the sub VI when you have saved and closed it. From 2011 even if you save your undo works but if you have closed the vi there is no way back.
Message 10 of 15
(4,744 Views)
