How can i call application in batch mode?
inside my application, when i open .avi file, i would like to compress it in batch mode for compression i am using virtual dub.
with regards
(3,330 Views)
How are you wanting to use LabVIEW with Virtual Dub? You can programticly launch Virtual dub from LabVIEW with the system exec function.vi . You can find it on the functions >> communications palette.
(3,330 Views)
but inside my labview source code how can i interface
virtual dub with system function?
any example please?
with regards
(3,330 Views)
LabVIEW can interface with external code by calling dlls and by ActiveX calls. It can make some memory calls but this method is less than desirable in LabVIEW. I do not have vitural dub installed on this computer. Does it expose an activeX interface or a dll with a header?
You can learn more about calling dlls in the shipping docs for LabVIEW. Open LabVIEW >> help >> search the LabVIEW bookshelf >> Using External Code in LabVIEW.
The best place to learn about activeX is on the web and in the LabVIEW user manual. Goto :
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a
and search for activex labview . The user manual can be found by opening LabVIEW >> help >> search the LabVIEW bookshelf >> LabVIEW User Manual.
(3,330 Views)
