How can i create a custom control, indicator
This is FredFred,
How can i create a custom control switch with 3 or more options,
OFF
ON
STANDBY
Other than rocker, slide, or toggle switch, are there other switches that we can use, hence, the question of creating a custom switch.
Also, is there a way to create an indicator with two options. Enclosed is a jpeg with an example of what i need
Thanks in Advance
(2,855 Views)
Hello.
Boolean controls can only have 2 possible values, true or false, and there is no way to add more values to them.
If you need more values, then you must use a numeric control (or a string, but I tend to like numerics better, although strings could be just as useful).
There are several types of numeric controls you could use to provide 3 or more options. Attached is a VI which shows a ring, a knob, and a slide each with 3 possible values. In your code, you would then perform different actions depending on the numeric value of your control.
Hope this helps,
Alejandro
(2,831 Views)
