How can i create a custom control, indicator
This is FredFred,
How can i create a custom control switch with 3 or more options,
OFF
ON
STANDBY
Other than rocker, slide, or toggle switch, are there other switches that we can use, hence, the question of creating a custom switch.
Also, is there a way to create an indicator with two options. Enclosed is a jpeg with an example of what i need
Thanks in Advance
(2,897 Views)
There are multiple possibilities. One is a knob control with text labels. Another is a radio button control. With a bit of customization, either should give you what you need.
Steven H.
(2,884 Views)
