How can i create a driver VI when I use RT model?
Now I am using SIT,and want to connect the simulink model with labview and then connect the hardwire. When I open MATLAB, the command window dispalys "starting the SIT server on port 6011 SIT server started". I do not know what does mean "on port 6011",if I do not have the hardwire, do I need to change the port, and How can I change it?
The second question:
I am tring a exmple named sinwave according to the LABVIEW help, when it comes to creating a driver VI, I am confused, and I do not do it.
Look forward to your help,thank you!
Regards
vivian
Message 1 of 1
(2,382 Views)
