How can i find 8451 & I2C example code.(Labview 7.1)
! will have to commuicate Data Read and Write
(USB-8451 &  I2C(ST24C16) direct connection status)
I want to Detail text and VI Example.
Thank you.
(4,444 Views)
If you installed the NI-845x driver, it should have installed in LabVIEW examples in the Example Finder. These will be configured for the 8451 but not necessarily your specific I2C device. The examples are located in the Hardware Input and Output»I2C and SPI folder in the Browse view of the Example Finder. I hope this helps!
Missy S.
Project Engineer
RoviSys
(4,418 Views)
