How can i finisch the whole Programm with only one buton
I use While and loop in my Programm.Sometimes i use stop buton to end the programm.but the others runs .How can I end the general programm with only one buton(Stop).thanks!!
(3,248 Views)
I recommend Quit LabVIEW Function.
That path is
Function->Application Control->Quit LabVIEW
(3,248 Views)
If you're talking about multiple while loops, the simlest thing to do is create local variables of the stop button and monitor those in the other while loops.
(3,248 Views)
This would certainly work, but a less drastic measure would be using the local variables as Dennis suggested. This allows you to retain some control over they way you quit, and prevents you from having to re-start LabVIEW numerous times during development.
(3,248 Views)
He want to end program.
If he desired to stop program,I would propose
global/local variable.
(3,248 Views)
You have to first use the local variables to stop all the while loops in a controlled manner and then you can use the Exit function. Doing anything else is flirting with disaster.
(3,248 Views)
Thank you a lot.I can this now
(3,248 Views)
