How can i generate 4 finite pulse trains with 90 180 270 phase shift using 660x simultaneously?
Is there any example code to do this ?
(2,502 Views)
Create a Task in MAX named e. g. 4Phases. As first channel use ctr0 and configure ist as 2m High, 2m Low, Start Low and 0. As second channel use ctr1 and configure it as 2m High, 1m Low, Start Low and 1m. Third channel on ctr2 configured as 2m High, 2m Low, Start High and 0. Fourth channel configured as 1m High, 2m Low, Start High and 1m. This will generate the four signals with 250 Hz. You must ajust the times for other frequencies.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,500 Views)
