How can i get the images from a picture ring into a cell in Excel?
Hi
I need to get the chosen image from a picture ring into a cell in a Excel worksheet. If i use an invoke node i only get to write a picture from file. How can i get the picture directly from the picture ring into Excel?
Kenneth
(2,489 Views)
No, there is no simple way of doing it directly. You need some clipboard manipulation which means you need to write some codes in excel as well. Importing the image through a file is much easier.
-Joe
(2,481 Views)
