How can i initialize a button (Switch when pressed) to be always disabled when i start the programm.
Hello
How can i initialize a button (Switch when pressed) to be always disabled when i start the programm. My problem is that the state of the button is always the state in which it finihed last time.
Lukas
(4,827 Views)
Hi Lukas
Just create a local variable of the button (right-click on the block-diagram >> create >> local variable) and wire the appropriate constant to it.
You just have to place it correctly, depending on your program.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,820 Views)
A button is either true or false. "Disabled" is a property that determines if the button can be operated or not. 😉
It seems from the rest of your question that you actually want to ensure that it is set to false, but remain enabled. This is easiest done with a local variable as already mentioned by becktho.
If you want to disable the button, use a property node.
(4,811 Views)
