How can i know what SubVI is on SubPanel?
In the main of my application i have three subpanels that open many different SubVI, i need to know what reference of subvi is actually open
what could be the best way to do it?
thanks,
Andres
(2,635 Views)
I'm not aware of a way of directly getting the VI reference from the subpanel control after a VI has been inserted into it. Seems like an oversight to me if it's not there. This means you will either have to create a mechanism for saving the reference that's currently open at the time that you invoke the "Insert VI" method, or you can use a roundabout means like getting the run state of a VI or reading an indicator's value, as mentioned in this thread.
(2,622 Views)
thank you for the help ... how i suppose isn't possible by intrinsically functions!
Andres
(2,611 Views)
