How can i modify parameters in the web page of a device
Leo_Fenner
Member
I need to configure a wifi device through its web page and its time consuming. Can anyone help me to automate this through labview.
Br,
Leo Fenner Fidelis P.
5 REPLIES 5
muks
Proven Zealot
Re: How can i modify parameters in the web page of a device
Message contains a hyperlink
Leo_Fenner
Member
Message contains an attachment
My application is not related to data aquisition. I just want to select the options in the web page attached through automation instead of manual.
Br,
The_Devil
Member
I would like to know more about your application sir.
What is the hardware you are using for the application and what are trying to do in application can you please elaborate on the same?
As far as I understand your query you are mainly trying to use the webservices in LabVIEW. The following link will guide you about using the web services and the web scripting. Also I have given you a link of the FAQ's for webscripting. Hope it help and incase you have any more doubts please let me know.
https://forums.ni.com/t5/Example-Code/Scripting-in-LabVIEW-Web-Services/ta-p/3996297
https://www.ni.com/en/support/documentation/supplemental/08/labview-web-services-faq.html#section-77...
Priyank
Leo_Fenner
Member
Hi Priyank,
         Thanks for the help. I will get back to you after looking into the URL u gave me.
Br,
The_Devil
Member
Hi Leo Fenner,
Hope the links helps you with your application. Let me know for further assitance.
Priyank
