How can i monitor temperature in climate chamber TCC 4025 using labview and myRIO?
I am working with my Bachelor Thesis and i am running out of time. Anyone can help me on this problem?
Message 1 of 11
(5,106 Views)
The chamber has a controller on it right? You could connect to it to find out what the internal temp is.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(5,094 Views)
But I want to develop a remote control from pc for this CC
Message 3 of 11
(5,087 Views)
The best way to do that is with a dedicated controller (Thermotron makes many good ones) and use the PC to control the set point. The problem with building your own control is reliability. There is no way a PC will be as reliable as a dedicated COTS (commercial off the shelf) controller. And let's not forget the cost required to reinvent this particular wheel.
Mike...
LabVIEW Champion
Message 4 of 11
(5,078 Views)
If the chamber has a communications port (e.g. RS-232 / Ethernet / USB), then it's possible that you can communicate with it remotely - you'd need to look it up in the datasheet/manual for the chamber (or contact the manufacturer). I've communicated with chambers over RS-232 that use MODBUS in the past and you can set the temperature, as well as read out temperature/humidity information.
Of course, if you just want to monitor the temperature, why not wire up a temperature sensor and stick it inside the chamber? There are many different types (e.g. thermocouple, RTD etc.) with different types of interfaces (e.g. analogue, SPI etc.) - most of which you should be able to hook up to a myRIO.
(blog)
Message 5 of 11
(5,064 Views)
can i know more about your past project? this chamber has RS-232.
Message 6 of 11
(5,057 Views)
There wasn't really that much to it - it was a PC application which communicated with a chamber to run the chamber on temperature profiles whilst reading data from a device under test.
The chamber used MODBUS so I read the documentation for it and then used a LabVIEW MODBUS library (from NI - available in VI Package Manager) to read/write the correct MODBUS registers.
(blog)
Message 7 of 11
(5,052 Views)
is there step by step that i can follow?
Message 8 of 11
(5,035 Views)
The vendor can provide documentation for how to use the serial interface - perhaps even examples. That would be the place to start. How pressed for time are you?
Mike...
LabVIEW Champion
Message 9 of 11
(5,009 Views)
I have about 2 weeks left 😞
Message 10 of 11
(4,991 Views)
