How can i multiplex sensors using the FPGA
Im using a Robotics starter kit, and the FPGA chip is too small for the code i try to put in there, so i am trying to make several functions smaller.
I am using 8 identical sensors and i have a subVI which returns the distance measured and wheather the sensor timed out or not, but i dont know how to re-use the same function for every sensor.
Can somebody help me?
Multiplex help
Message 1 of 14
(4,820 Views)
not enough information to help you yet.  what is the code within the measurement function?
if it has memory like a shift register, you either need to code it as an array or use memory to implement a piece of code that be iterated on within a loop.
Stu
Message 2 of 14
(4,817 Views)
Thats a good point. I added the entire code, so maybe you can take a look?
I cant seem to put the IOadresses into an array... Maybe it is possible and maybe its the solution to my problem 🙂
tnx in advance
Message 3 of 14
(4,812 Views)
Maybe this will help 🙂
Total subVI:
Pieces of the subVI(enlarged):
Message 4 of 14
(4,804 Views)
I tried to make an array of the 8 IOpins, but when I try to make a for-loop to use them all i get multiple error messages:
"Possibility of Dynamic Refnum not supported for current target"
When I make it a fixed-array I get the same error message Smiley Mad
Message 5 of 14
(4,791 Views)
The best solution would be to create a separate while loop for each of the sensors (see attached image).  I tried this with the sensor loop, and it compiled fine for an sbRIO-9631.
You should avoid calling the Measure Distance sub VI sequentially in a For Loop because the VI takes up to ~20 ms to run.  This is how long it takes for the ultrasonic sensor to receive a response pulse at maximum range.  Running the VI in an 8-iteration For Loop would result in 1/8th the sensor frequency for each sensor.  Using parallel loops will avoid this problem.
Chris M
Message 6 of 14
(4,769 Views)
are all of these events synchronized?  as in they are all initiated at the same time and should complete within the same timeout?
How often is the sequence repeated?
I understand that you are trying to fit onto the FPGA and are looking to reduce the code footprint by multiplexing the code.  I also assume that you need the digital input response to be as fast as possible to provide the best resolution.
Stu
Message 7 of 14
(4,765 Views)
For some reason I can only fit 2 sensors into my FPGA module...
I need a minimum of 4 sensors...
Message 8 of 14
(4,732 Views)
Have you made any other modifications to the FPGA code, other than adding extra sensor loops?  Can you attach the modified example you are trying to compile?
Chris M
Message 9 of 14
(4,726 Views)
The project contains 2x  dualmotordrive units, 8 simple digital sensor connectors, SPI-communication, a custom serial comunication for a linescan module and hopefully 4 ultrasonic sensors
Attached the entire project(.7z file in a .zip file because 7z is not supported on this forum). Hope somebody can help :-S
Message 10 of 14
(4,718 Views)
