How can i plot X-Y graph if I'm having multiple plots
I have 2 y-axis and 1 x-asis.
can anyone help me develop the x-y graph please.
Thanks in advance
Screenshot attached
(2,828 Views)
Hi akshay,
a plot in a XYGraph can be supplied as cluster of [X array, Y array]. To have more than one plot you can create an array of those clusters - as is explained in the context help of the XYGraph!
Where are you stuck at creating the plots?
To get that 2nd Y axis you need to create the Y axis using the context menu of the graph (aka right-click menu), then create Y axis, then swap side of the Y axis…
(2,822 Views)
I wanted to know how can i plot the second curve in the same graph after plotting the first curve
(2,794 Views)
Hi akshay,
follow the context help to learn how to wire multiple plots…
(2,777 Views)
My X-Y graph takes the values from only one Y-axis.
Is there a way to select the particular Y-axis.
(2,762 Views)
Hi akshay,
right click the plot in the plot legend -> select Y axis for that plot.
(Or use a property node for that plot to select the Y axis…)
(2,758 Views)
