How can i read color from TCS230 Color Recognition Sensor module with Arduino uno r3
I received orders from teachers to create a color classification machine using Labview and I just studied Labview. Now I have the TCS230 Color Recognition Sensor module. Anyone can help me.
(3,163 Views)
There's a tutorial describing the use of this sensor with an Arduino here: https://howtomechatronics.com/tutorials/arduino/arduino-color-sensing-tutorial-tcs230-tcs3200-color-...
Do you intend to use an Arduino as well?
If so, how far have you gotten? Try the tutorial and then we can discuss communication between LabVIEW and the Arduino.
If not, what hardware will you use instead? You'll need to write LabVIEW code taking similar actions to the Arduino code in the tutorial.
Let us know what you've done and how you plan to continue.
GCentral
(3,142 Views)
Hello! Have you complete your project with TCS230 and labview, I would like to know how you did it.
(2,304 Views)
