How can i register a graph or a chart on my computer?
I'm a new user of Labview and i have a problem: I have to test something with Labview. So, i will obtain a graph (or a chart) and i would like to be able visualizing it after. I don't know if i must use a graph or a chart and i don't know how i can register it on my computer. Thank you to explain me how i can do and if it's possible to send me a program to show me.
(2,593 Views)
Essentially the difference between a graph and a chart is that a graph is used to display an array of data and a chart displays data one point at a time. So if you're acquiring some data and then want to display it, use a graph. If you want to display each datum as it's acquired, use a chart. There are a lot of graph and chart examples shipped with LabVIEW. I don't understand your question about registering it on your computer. If you could provide more detail on what you want to do, it would be easier to help you.
(2,593 Views)
Assuming that registering means saving data in order to be able to view the same graph later, you have to decide first if you need to use a graph or chart (to do this, play with graph/chart examples and see wich one is good for your application or let us know about what do you want to display on that graph/chart). After, you can choose one way of saving data, writing to file:
- as binary data
- as string, after conversion
- as waveform
Hope this help
(2,593 Views)
