How can i resolve the file could not be loaded in labview error code is 0x2A
Maybe by giving more details.
What are you doing leading up to this error?
Is this Windows or an RT system?
Did it work before?
What is your LabVIEW version?
(382 Views)
Something is "strangely wrong" with a file called "Main Screen.vi", which you appear to be trying to open with LabVIEW.  Do you want suggestions on what is wrong with this unknown (presumably LabVIEW) file?  What additional information do you think you should provide to us so we can make constructive suggestions?  [Hint -- it involves something called "Main Screen.vi"].
Bob Schor
(344 Views)
