How can i send a double array(full of doubles) to an output file?
I have a double array which is full fo doubles in it. And I wanto to write these data to an output text file? Can someone show me a way of doing this?
(2,850 Views)
Hi tenten,
do you really need a text file? So you could use "Array to spreadsheet string" (from string palette) and "write to text file" (LV7.1).
In newer LV versions you find a vi in the file palette (Write to spreadsheet file) which does this in one step...
In both cases you need to give proper format codes to keep your information correct (%.3f is default, but will probably cut most of your informations)!
Message Edited by GerdW on 09-25-2007 03:32 PM
(2,854 Views)
For the sake of being throroughly helpful...
Attached is what your looking for.
(2,838 Views)
Hi Tenten,
Those were all excellent suggestions above. There are many options. I have added a simple VI so you can have an example with a Text File.
Charlie M.
Message Edited by Charlie M. on 09-26-2007 02:50 PM
Message Edited by Charlie M. on 09-26-2007 02:51 PM
Charlie M. CLD
(2,807 Views)
