How can i send a waveform graph from labview to matlab
i am acquiring a PPG  signal from NI  DAQ in labveiw
i want to export  this PPG signal to MATLAB  2012 for further processing
how can i do this?
(3,272 Views)
Hi Irfan789,
With the data from the signal, you can write this to a spreadsheet file, using the write to spreadsheet.vi located in file I/O which will convert your data into ASCII format. You can then open this file in the MATLAB environment by typing
>>LOAD filename
More information can be found in the following KnowledgeBase article.
http://digital.ni.com/public.nsf/allkb/2F8ED0F588E06BE1862565A90066E9BA
Jinfone
(3,091 Views)
