How can i send more than one signal to DMA FIFO?
i've never done! now i see that in the wave chart and i want to see a perfect sine wave like that.
Message 11 of 22
(2,720 Views)
So it looks like you are writing to the waveform chart incorrectly.  Please show your code.
Message 12 of 22
(2,712 Views)
Here it is!
Message 13 of 22
(2,703 Views)
Accepted by topic author pablosan
You are not writing arrays to your chart.  Plus it looks like you have two of your plots disabled.  See if this works for you.
Message 14 of 22
(2,691 Views)
i try that and I have the same problem!
Message 15 of 22
(2,673 Views)
1.  Why the FOR loop for the DMA write?  it isn't doing anything.
2. I am noticing a coercion dot on your DMA write.  What is the data type you have for the DMA FIFO?
3. Try zooming in on your chart.
Message 16 of 22
(2,663 Views)
1. I've just delated the for loop for the DMA write
2. the data type is I64
3.The wave is not a sine wave
Message 17 of 22
(2,655 Views)
Those signals look like you are saturating your D/As (clipping at the peaks).  You should look to see what exactly you are inputting.
Message 18 of 22
(2,649 Views)
the inputs before the write DMA FIFO is well. If the amplitude is 1 i can see 3 sines waves between  [-1, 1].
I think the mistake is after the read DMA FIFO.
Message 19 of 22
(2,645 Views)
What's the output datatype of your Integer to FXP conversion?
Message 20 of 22
(2,607 Views)
