How can i set this comparison in formula node
a=[0,100]
a<=5          => x=1
5<a<=10    => x=2
10<a<=95  => x=3
95<a<=98  => x=4
a>98          => x=5
Thank you.
Message 1 of 8
(4,747 Views)
Accepted by topic author keremgeliz
if (a <= 5)
x = 1;
else if (a <= 10)
x = 2;
else if (a <=95)
x = 3;
else if (a <= 98)
x = 4;
else x = 5;
Message 2 of 8
(4,742 Views)
Why use a formula node?
Message 3 of 8
(4,726 Views)
GerdW, you need to add a max value to the end of your array (whatever the max I32 value is).
Message 4 of 8
(4,701 Views)
Hi Crossrulz
input "a" is limited to range [0, 100]. Atleast the OP said so…
Message 5 of 8
(4,684 Views)
Thanks for your help. But i need this solution in formula node and i think i fix it. Now its working.
if (x<= 5)
a = 1;
else if (x <= 10)
a = 2;
else if (x < 95)
a = 3;
else if (x < 98)
a = 4;
else if (x >= 98)
a = 5;
Message 6 of 8
(4,664 Views)
Then you should mark BowenM's message as the solution to your question since he was the one who provided you the code that you are now marking as the solution in your message.
Actually your last message is wrong since you've gone and swapped the variables a and x from what you had originally described in your original question.
Please go to the Options menu to the upper right of your last message, pick unmark as solution, then go and mark BowenM's message as the solution.
If it was me, I'd use Gerd's code since it keeps it all in pure LabVIEW functions.
Message 7 of 8
(4,640 Views)
You copy my code, add an error (given your initial request), post it, and mark it as solution?  Rude.
Message 8 of 8
(4,634 Views)
