How can i shorten series of writing strings
Hi all!
My problem is following.. I need to write serias of strings to a power supply to scan the field with specific interwals. such as %scurr 0, %scurr 0.03, %curr 0.06... and i need to take a measurement with a multimeter between each step. Well, I can do that by using sequence loops for short range. But the problem is when i want to scan between 0 and 20 with step of 0.03 ,i have top use around 300 loops.
is there anyway to make it easier? what kind of vi i hould create?
thanks
(2,724 Views)
Is the attached picture helpful ?
Although not neetly done...
_Deepu
(2,720 Views)
Looser,
You really need to understand that there is no such thing as a 'sequence loop'. It is a sequence structure and does no looping. The example provided by Deepu has a real loop. In this case a for loop. There is also a while loop and a timed loop. A sequence structure is just used fo control execution order is usually not required at all.
(2,703 Views)
thanks Dennis!
(2,697 Views)
