How can i show or hide any page in tab control at run time?
(3,024 Views)
Hi Jawad,
It can be done by: right click at the "Tab control", select "Create" ->"Property node" ->"Pages"
Now you have this property at the block diagram.It's output is an array.Wire it to "Index array.vi",
and as index use the page you want to enable/disable. Now, get the output of "Index Array.vi" ,
right click ->  "Create" ->"Property for Page Class" -> "Page Visible".
right click -> "Change to write".
Now you can wire to it your desired state.
Michael
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(3,017 Views)
Use property nodes for of Tab, as shown in attached VI
(3,015 Views)
Hi,Misklyar thanx for help.Your code solve my problem
(3,007 Views)
Hi, Devchander  thanx for help.
(3,005 Views)
