How can i take a number of a serie of numbers?
My question is if i have a file.txt and it has this number 76546456567 for example how can i take each number separetly
first de 7 then 6 into array.
I have to make a display conect to the DAQ which displays each number of a serie, first 7, then 6 etc.
(3,187 Views)
There are a number of possible solutions. Here is one...
CC
Chilly Charly    (aka CC)
(3,182 Views)
Sorry it doesnt work to mi i have version 6.1
But anyway thanks.
(3,178 Views)
Here is a 6.1 version.
(3,173 Views)
Thanks a lot it works perfectly.
(3,172 Views)
Here's a loop-free version (LabVIEW 6.1). 🙂
Depending on your requirements, you need to check for errors, e.g. if one of the characters is not a number. CC's version will give you zero while this version will give you a number that is outside 0..9.
(3,168 Views)
