How can i use labview for communicating with pic18 microcontroller through usb port?
Hi all,
I want to make a DAQ card using pic 18 microcontroller which has a built-in usb protocol. I have the firmware of this
controller which will  make it as a usb device. How can i receive the analog voltages from this DAQ card in Labview? or i mean to say that how i can communicate labview with the Pic 18 microcontroller through usb port? I have also the
mpusbapi.dll file which is for Visual C++. Can i make changes in this dll file to make it compatible with labview?
Message 1 of 13
(6,081 Views)
I'm not sure what this dll should be, but you can call in in LabVIEW with the Call Library Function Node.
To work directly with the USB Interface just search the forums for "USB Raw Communication with LabVIEW".
Hope this helps,
Christian
Message 2 of 13
(6,080 Views)
Thanks for your reply. Can you send me the link of the tutorial for using call library function and for communicating
labview with usb device?
Muzammil_IIEE
Message 3 of 13
(6,067 Views)
So what I would do know is go into the LabVIEW help, search for Call Library Function Node, read it, look for an example, send you the example and the helps content. Then I would go to ni.com, or forums.ni.com, click into the search field and type USB Raw Communication LabVIEW, then I would get lots of links and post them here for you.
Don't you think you can do that by yourself?
Message 4 of 13
(6,064 Views)
Which labview version do you have. Up to labview 7.1 it was no USB raw communication options. I have heard it did not work well in 7.1, but from 8.x most of the errors were fixed.
Here is a link it should be useful http://forums.ni.com/ni/board/message?board.id=170&message.id=340676&query.id=365864#M340676
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 13
(6,060 Views)
muzammil_IIEE wrote:
Hi all,
What hardware do you have?
Just a PIC 18F..... controller IC as such or is it mounted on a development/evaluation board?
So you have some code to implement an USB port in the PIC but you still don't have code to read some analog signals in that PIC. Such code can't be written in LabVIEW.
The mpusbapi.dll is a Microchip dll right?
So can you please be more specific regarding the hardware you have?
Thanks for that!
Message 6 of 13
(6,056 Views)
You seem close to understand my problem. I have pic18F4550 IC and i want to make DAQ card by using this
IC. I am not using any evaluation board of microchip. I want to  make a DAQ card which consists of this IC and
it will read analog voltages and just transfer it to the PC ( on labview) . I have the firmware of usb of pic 18 series
but that firmware is for microchip's evaluation board . so I have few questions to ask
1) What changes do i have to make in that usb firmware to develop the application for non- microchip evaluation
     board?
2) mpusbapi.dll is a dll of microchip, but it is for visual C++. Do i need to make any changes in this dll file?
     or i can directly use "call library function " to call this dll file without making any changes to it.
Waiting for your useful reply
Message 7 of 13
(6,039 Views)
To be honest I'm not familiar with PIC's, I prefer 8051 based µC Smiley Tongue
Anyway it's indeed what I thought, you have only part of the code needed in the PIC, the USB part.
Now you first need to write code in the PIC to read the analog and/or digital inputs and transfer the data through the USB port.
Then you can use the dll to communicate with the PIC. You can indeed use "call library function" vi's but be sure to have the correct datatypes connected or it will go wrong Smiley Sad
Finally some links that can help you:
Forum with some PIC specialists to help you with the PIC code, especially Nigel Goodwin 🙂
You're not the first is this what you want to do?
Good luck!
Message 8 of 13
(6,032 Views)
Have you tried to Google the phrase ->microchip usb labview. I did and I think you will find some useful links
Message 9 of 13
(6,021 Views)
Thanks a lot Alain for sending me some useful links. I will definitely now get some direction now but in the upcoming
days , if you find some more solutions to my problem then please send.
Message 10 of 13
(6,019 Views)
