How can i use the SNMP and TCP/IP together in Labview?
I want to use the SNMP and TCP/IP together in the Labview to communicate between the two computers, If anyone know about it , please write back.
Santosh Chavan
IIT MADRAS.
(3,439 Views)
Check out the SNMP Toolkit from http://www.viodia.com/.
(3,424 Views)
Dennis Knutson
Santosh Chavan
IIT MADRAS.
(3,414 Views)
You can use LabVIEWs UDP functions to communicate with SNMP devices. The tedious part is converting the MIB information into the required hex message.
There is also a problem in using the UDP functions on port 161 (default SNMP port) if the Windows SNMP services is running.
(3,360 Views)
