How can i verify the licenced addons/ toolkits installed in Controls palette LabVIEW Environment?
Hello ALL,
I have licence for student install version of LABVIEW. I am new to the LabVIEW.
I have installed licence LabVIEW Digital Filter Design Toolkit in my laptop. But i am unable to find the digital filter options under signal processing of the Controls palette. Its not there despite of installation. I have checked in the NI licence Manager it says Digital filter design toolkit has been activated for this computer.
Can someone please help to locate the digital filter options from that particular toolkit? How can i verify the functions in control palette for the toolkit i have installed?
Thank you
Ihave the licnece fot the following Content:
LabVIEW Student Development Environment
LabVIEW Toolkit for LEGO MINDSTORMS NXT
LabVIEW Control Design and Simulation Module (Installed)
LabVIEW MathScript RT Module
LabVIEW System Identification Toolkit
LabVIEW Digital Filter Design Toolkit (Installed)
LabVIEW Modulation Toolkit
LabVIEW SignalExpress
NI Vision Development Module
NI Vision Acquisition Software
NI DIAdem Student Edition (Installed)
NI LabVIEW Real-Time Module (Installed)
NI LabVIEW FPGA Module (Installed)
LabVIEW Database and Supervisory Control Module
LabVIEW Mobile Module
LabVIEW PID and Fuzzy Logic Toolkit
LabVIEW Robotics Module
LabvIEW Simulation Interface Toolkit
LabVIEW SoftMotion
LabVIEW Statechart Module
Motion Control and Motion Assistant
Message 1 of 8
(6,426 Views)
Accepted by topic author chndn021
In Labview 2014 32 bits, it can be found in signal processing->digital filter design.
In Labview 2014 64 bits, I couild not find it either. I know that some toolkits are not supported in LV 64 bit.  I could not find documentation on system requirements for this toolkit so I could not confirm this, perhaps you can change to LV  32 bit?
Good luck,
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 2 of 8
(6,385 Views)
Hey,
Thanks. I had 64-bit LabVIEW.
Now, i have installed 32-bit and checked it, digital filter design option was there. Thank you so much.
Message 3 of 8
(6,373 Views)
For future reference this page has charts that track toolkit compatibility with LabVIEW 32/64 bit:
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 4 of 8
(6,360 Views)
You're welcome 🙂
― Terry Pratchett
Message 5 of 8
(6,330 Views)
Hi Craig,
The link you posted doesn't specify compatibility with LabVIEW 32/64 bits, but with Windows 32/64 bit. Is there such a document for LabVIEW versions? For example, I know the data finder toolkit is not supported in LV 2014 64 bit, and we now know the digital filter design isn't supported either.
Danielle
― Terry Pratchett
Message 6 of 8
(6,328 Views)
Note how the charts say "Windows 7 64-bit
(Using 32-bit Software)" and "Windows 7 64-bit
(Using 64-bit Software)"
32 bit software corresponds to LabVIEW 32 bit, and 64 bit software corresponds to LabVIEW 64 bit.
So they should demonstrate both windows and LabVIEW bitness compatibility!
Here's another document that links to additional compatibility charts for more versions of Windows:
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
Message 7 of 8
(6,302 Views)
Thanks Craig, I don't know how I missed that (twice!) 🙂
― Terry Pratchett
Message 8 of 8
(6,276 Views)
