How can labview pass subpanel ref between ppls
Hello LabVIEWers,
Currently I'm trying to use ppl with actor framework and MGI Panel actor, every backend code worked fine. However, when I want to pass subpanel ref from one of my ppl to my root actor then use root actor to launch another nested panel actor but ui shown in the ppl subpanel, it failed to show in that subpanel. launch panel actor with subpanel typelaunch panel actor with subpanel typepass subpanel ref to rootpass subpanel ref to roothave successfully load in memory but not shown in subpanelhave successfully load in memory but not shown in subpanel
Message 1 of 1
(990 Views)
