How can my VISA control communicate with an instrument via TCPIP?
The VISA controls find my GPIB instrument when I select "Refresh", but none of the TCPIP instruments. I know the TCPIP instruments are connected because I can ping them.
(3,173 Views)
Accepted by topic author bmihura
if you're looking for how to build the resourcename, it can be found over here
TCPIP SOCKET TCPIP[board]::host address::port::SOCKET
e.g.
TCPIP0::1.2.3.4::999::SOCKET Raw TCP/IP access to port 999 at the specified IP address.
TCPIP::dev.company.com::INSTR A TCP/IP device using VXI-11 located at the specified address. This uses the default LAN Device Name of inst0.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,170 Views)
Did you create the VISA TCP/IP resource in MAX first?
(3,161 Views)
How is that done? I've used MAX for NI devices and other GPIB devices, but never TCPIP. I can't find this in MAX's help either.
(3,156 Views)
Right click on Devices & Interfaces and select Create New>VISA TCP/IP Resource. Since you marked your question as solved, why are you asking?
(3,149 Views)
I'd like to know how to do this in MAX, even though that first answer solved my problem.
I actually read about the "Devices and Interfaces" item in MAX's configuration tree, but my MAX's tree does not have this. It only has this, as shown in the attached screenshot:
My System
   Software
Remote Systems
How do I get "Devices and Interfaces" into that tree?
(3,142 Views)
Hold on, I'll ask that in a new thread so you can get points.
(3,141 Views)
