How can open a SubVI but in the same ppal of the principal VI?
hi, within a case structure, I want to send to open a subVI but I don't want that open in a separate window, I want to this subVI panel inside the main panel VI. can you help me? Thanks.
(3,500 Views)
Have you looked into using a subpanel?
(3,469 Views)
for easy solution make terminal out from sub vi and use property node and visible item and make true inside case structure so you will have your indicator and control visible or invisible
(3,443 Views)
Hi DanyckV,
Denis is right, the best way to open sub-VIs into your main FP is to use subpanel control.
here how you can proceed.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OX6SAM&l=en-US
https://www.ni.com/docs/en-US/bundle/labview/page/loading-a-front-panel-in-a-subpanel-control.html
Good luck
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,435 Views)
