How can the TCP Read buffer be cleared or data flushed?
(5,166 Views)
Try using TCP Read with a large number of bytes to read and a small timeout.
___________________
Try to take over the world!
(5,158 Views)
Thanks for your suggestion, I have thought about that, but was hoping for some property/function similar to the Serial RX/TX flush. I had thought that there would be one but have been unable to locate such a mechanism.
(5,154 Views)
There is no specific method for flushing the buffer in LabVIEW. However, you can get this behavior by doing a TCP read with the Mode set to immediate. This will return all data currently available (which could then be ignored) and clear out the read buffer.
Matt F
(5,142 Views)
Thanks for the additional info. Since the app is time sensitive, I am experimenting with TCP read with controlled timeout. Thanks all again for the suggestions.
Cheers,
Don
Rochester, NY
(5,138 Views)
