How can you display a dynamically loaded vi to the Web Server?
I am working with LabView 6.1 and the Web Server. I can call a subvi and have it display on a remote machine using a browser with no problem. But what I would like to do is dynamically load and run a vi and have it display on the remote computer using only a browser. I have tried a small example of a front panel that invokes the run vi method (and fp.open prop) on another vi when a button is pressed, but the invoked vi is displayed only on the local computer. Is there any way of viewing dynamically loaded vi's on a remote machine without having a copy of LabView running on it?
(2,497 Views)
If i understand your question correctly, you want to monitor vi that are dynamically loaded on a remote machine without having LabVIEW installed on the machine from witch you want the monitor. I don't think it's possible how ever a good reference book would be Internet applications in LabVIEW. You can find it on BARNES&NOBLE.
Hope i could help
(2,497 Views)
