How can you get the index of an enum instead of the value of the enum?
Im new to labview and I am trying to read out the index of an enum oppose to the string value the enum has.
i.e. for example an enum of values 1, 5, 10, 20 with indexs 0,1,2,3  I want to take the index value to use in a code as a string,
so take the 0,1,2,3 values
Are there any simple solutions?
Cheers,
JimJamBot
(13,685 Views)
Accepted by topic author JimJamBot
It is already a number.
Try using a "to I32" or similar from the numeric palette.
Ben
(13,675 Views)
That worked, Thank you!
JimJamBot
(13,670 Views)
Enums also have amazing feature when converting them to string:
If you wire it into Format into string and specify %d as formatting, it will be numeric string (0, 1, 2...). If you specify %s, it will be string you see on block diagram (1, 5, 10, 20) in your case
(13,633 Views)
That's cool, I think that just made a load of my code alot simpler,
thank you,
JimJamBot
(13,608 Views)
