How can you verify if a vi on a remote system is running?
Is there a way to positivly determine if a VI is running using VI server? I have a standard PC peer to peer networked to a PXI chassis. Reading a boolean on the remote vi works unless the vi was shut down incorrectly as the boolean stays at it's last state. I know you can check to see if a vi is in memory, can you check the status of it as to whether it is running or not?
thanks
(2,558 Views)
Under VI properties, execution, state. Reading this will give you that information.
(2,558 Views)
