How connect bluetooth DBT-120
Hi, I need to connect a bluetooth device DBT-120 (usb dongle)directly from labview from a pc without use its software but I receive the error 58 from Labview. I work in winvp SP1 Can'you help me?Thank's
(3,458 Views)
I think that as a first step you should make sure that your BlueTooth device is fitting in the requirements listed on the following web-based document:
http://zone.ni.com/devzone/conceptd.nsf/webmain/5EB9312A6470F16A86256E7500726F15?opendocument
Here it says that the device should be using the Microsoft bluetooth driver in order to be driven directly by labview.
I hope that the information reported on this document can help you in solving your problem
AlessioD
(3,457 Views)
Hi I read the document few days ago. The problem is about to ind a dongle bluetototh compatible with driver Microsoft Windows XP SP1.
Can I control DBT-120 directly from LabVIEW
This is my problem.
I read from forum can be possible with DBT-120 but how?
Thank's
(3,457 Views)
hi,
can you get me the link where you read that it is possible to communicate with a DBT-120 device from LabVIEW?
thanks
(3,457 Views)
Hi and thanks for help.
it's a post into forum you can retrieve with "bluetooth rfcomm service discovery"
It's a post of "fadenoid"
best regerds
elisa
(3,457 Views)
