This widget could not be displayed.
How could I disable open/close action which is caused by double click?
When I double click the Level 1 and Level 2, all the children item will be opened or closed even on the symbols. But I don't want to see the open/close action caused by double click. Can I disable it?
(2,705 Views)
Accepted by topic author MoonSailer
Try the Mouse Down? filter event on the tree control:
(2,699 Views)
It works, great thx.
But why there is no Mouse Up? filter event? It would be more helpful than Mouse Down? filter event in my case.
(2,687 Views)
And why is that? I could imagine that each mouse down needs a corresponding mouse up event. When discarding the mouse down there's also no mouse up (didn't test this). When only discarding a mouse up event the "symmetry" would be broken because there's one more mouse down than mouse up. This could cause some code to fail.
(2,682 Views)
