How could I select more than one file in a dialog?
Hello NG,
is it possible by using a "file path - frontpanel element" to configure the dialog for the possibility of selecting more then one file? The return should be an array. At the moment, I am only able to choose one file or a whole directory. But I want to select different files of different directories and do not want to reopen the "file path dialog box" continously.
Thanks a lot for your help.
Michael
(2,414 Views)
Here's an example that uses the program you download from here. I also used a Boolean with the file browse icon that I got from OpenG. If you want, you can also check out this thread.
(2,395 Views)
